The first generation Honda Civic Hybrid wheels are not as nice as the Insight, but they are still pretty flat/smooth and I hear they are around 12lb as well, a junk yard in Colorado on Car-part.com has two of them for $75 each, but if you search with your zip code you can sort by distance from you, I searched on there for a 2003 civic hybrid to pull up the photo of the wheel so I knew I was looking at the right wheel.
That is the wheel I'll most likely get as I can get a set of four for $200 driving 40 miles to pick them up.
