Old 02-17-2012, 10:09 AM   #11 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by SentraSE-R View Post
It's all there in Mort's post #7. The power consumed (wattage) remains the same, but the amperage through the fan motor drops to half if the resistance in the circuit doubles by your adding resistors.
No it doesn't. Look again. The motor alone uses 100 watts. The motor with 12 ohm resistor uses a total of 14 watts, 12 through the restor and 2 through the motor. It isn't the most efficient way to slow things down, but it does reduce the total power substantially.
-mort
The Following User Says Thank You to mort For This Useful Post:
straight5 (02-17-2012)
