Old 02-17-2012, 11:41 AM   #4 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
My 2ยข. Waste Vegetable Oil is appealing because it saves the trouble of refining down your own Bio-Diesel. However, when you make Bio-D from vegetable oil you remove the glycerin (the stuff soap is made from). I have seen photos on other forums of some sludged up engines that have been running on WVO. There is a lot more mechanical complexity involved in running WVO with solenoids and heated oil tanks etc. My thought would be to get the diesel swap running well on Bio-D first and then see if you still want to go to the next step.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
