Old 02-17-2012, 11:15 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by GRU View Post
Even with 1 tooth off it will start and run. You probably got water/moisture in the electronics and once dried out it will start again.
That's good, simple advice. Patience. Wait and see if it dries out as suggested. For clarity, you are saying you checked for spark and you are getting it? When you are trying to start, the starter cranks but the engine does not fire up?
If it does not fire up after drying out, go back through the work you did, checking. Redo it. See if something you overlooked suddenly shows itself.
