Old 02-18-2012, 10:45 PM   #12 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
fuel and spark
fuel and spark
before you begin more advanced testing /
squirt some starter fluid into the throttle body ... does the engine start and run a few seconds and then stall ?
on the off chance that you has a DSO and know how to use it , this is the relationship of CMP cam position sensor (red Trace) and spark(green trace) during start , note the threshold of amplitude needed on the CMP voltage , you can measure this amplitude with a DVOM on AC volts scale
if you do not have a DSO , about 1 volt peak to peak when spark begins
your system does not have a CKP (blue trace)
if you have no CMP signal , you have no spark and no signal to Mr Fuel injector , no fuel , even if you do have fuel pressure in the fuel line
key on engine off
confirm the CEL is on
confirm you have 5 volts reference at MAP sensor
use T pins
like so
pierce not the wire or the insulation -
three wires on MAP sensor
1 has 5 volts
1 has between 5 volts and 0 volts
1 has 0 volts
with respect to battery negative ,
takes less time to test than to locate a wiring diagram to decide which wire should be what , just test all 3
if the above testing is all
"good"
you have screwed up your timing belt alignment - which is what i swag to be your problem
unless you were a complete zero and at the same time changed your oil and used 20w50 or 15w40
in which case the oil is the problem
elaboration can be provided if requested
Originally Posted by Mr. Previa View Post
Ok,
1992 Geo Metro 1.0, automatic
Today I cleaned the engine bay. Then, I replaced the cam seal, timing belt, distributor seal.
The geo will not start now. I am getting gas and fire. Do you think I got water some where or it is a timing issue?
On the timing issue - I was VERY careful not to mess it up. IF, I had one tooth off on the timing belt, shouldn't it still run? I noticed that the distributor will only go in one way and I am pretty sure that I installed it correctly.
Any ideas? Any and all help would be greatly appreciated!
Thank you.
