Old 02-19-2012, 01:02 PM   #261 (permalink)
kach22i
93 - 95 Ford Probe Check Engine light Codes
How to Read Trouble Codes From Your 1993 to 1995 OBD-I Ford Probe
Here is a complete list of MECS-II engine trouble codes, taken from "How to Understand, Service and Modify Ford Fuel Injection & Electronic Ignition Control." I offer this as a FAQ for those with 1993-95 Probes.
Basically, you can use a wire or a large paper clip to connect the GND pin to the TEN pin on your diagnostic connection. The connection is located in the front driver side corner under the hood, between the fender and the battery.
Dude, hot wire it to a reader like the guys in this thread.
Took me a single Google search to find this, where there is a will, there is a way.
