Old 02-19-2012, 02:40 PM   #13 (permalink)
Andrew63
Andrew63's Avatar
The Golden Lab - '05 Buick LeSabre Custom
90 day: 24.17 mpg (US)
Originally Posted by mwebb View Post
E = I x R
voltage = current in amps x resistance in Ohms
12volts = 12volts no matter what
so if R is increased then I must decrease ...
if resistance increases , current flow must decrease if voltage is constant
you can not break OHMs law , no matter how hard you try .
but
it will not change your FE more than the noise in your FE calculations
Ohm's law also says
Power consumed = Voltage * Current, and Current = Voltage / Resistance, so it can be restated as
Power consumed = [Voltage]^2 / Resistance
As resistance increases, the power consumed decreases for a constant voltage.
