02-19-2012, 09:40 PM
#15 (permalink)
120 psi is too low
with a fully charged battery
with all 3 spark plugs removed at wide open throttle
120 psi compression is too low ,
retry under conditions described above
should be 160 psi
minimum
if compression remains low on all three after the test is performed correctly ,
suspect timing belt misalignment
since this is affect all cylinders
looking more like timing belt misalignment OR
incorrect engine oil .
key on engine off
does the CEL light up ? check engine light . if no Mr computer is not waking up . engine will never start , conform by testing 5 volt reference at
MAP sensor , see above post
if you do not have a DVOM , go buy one , yesterday .
disconnect injector , go to clear flood , Wide Open throttle , operate starter until liquid clears from combustion chamber
then
without reconnecting injector
spray starter fluid into open throttle body .
if the engine starts then stall as starter fluid is used up , fuel quality is suspect .
what oil is in the engine ? it matters .
current OEM specification is
DEXOS1
search in google or whatever to see what that means
a better choice
is
a synthetic 5w30 or 0w30 or 0w40
with
ACEA A3 B3 A3 B4 specification
any other specification oil (than the choices above) should never be used in any Geo Metro
oils without ACEA specification and with API and ILSAC specification can never be used in any Geo Metro under any circumstances
Originally Posted by Mr. Previa
This morning the Geo tried to hit a lick. The plugs were very wet and did smell like gas. Could be gas/water mix? Ran compression tests. 120 on all. buttoned back up and tried it again. Tried to hit a lick again. I think there is too much gas/water in there some where.
