Old 02-21-2012, 07:40 PM   #23 (permalink)
Staska
Originally Posted by Sven7 View Post
So if you were to go through all this trouble of modifying your engine to run optimally with this stuff (which it sounds like they had to do even with crude 40's cars), where would you get large quantities of methane gas? Would your car even be able to switch over to a different fuel on the fly?
CNG does sound like a much better solution. Can you modify a gas engine to run it?
You dont't need a mechanical modification in engine. You need - a mixer device for fer feeding correct ratio of methane and maybe ignition time fine tune for spark ignition engines.
For diesel you don't need to modify anything. It will run on dual fuel then gas is present, or run on single diesel then gas is not present.
