Old 02-21-2012, 06:27 PM   #21 (permalink)
Take a look at the picture in the first post, and think about what that bag does to the CdA of the car.
A balloon would pretty much do the same.
-soD
Old 02-21-2012, 06:32 PM   #22 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
So if you were to go through all this trouble of modifying your engine to run optimally with this stuff (which it sounds like they had to do even with crude 40's cars), where would you get large quantities of methane gas? Would your car even be able to switch over to a different fuel on the fly?
CNG does sound like a much better solution. Can you modify a gas engine to run it?
Old 02-21-2012, 07:40 PM   #23 (permalink)
You dont't need a mechanical modification in engine. You need - a mixer device for fer feeding correct ratio of methane and maybe ignition time fine tune for spark ignition engines.
For diesel you don't need to modify anything. It will run on dual fuel then gas is present, or run on single diesel then gas is not present.
Old 02-21-2012, 08:01 PM   #24 (permalink)
Sven7's Avatar
I guess you'd have to do a VW diesel then because that's the only reliable diesel in a small US market car that I know of. If you have a MK3 Golf diesel I'd say go for it, but maybe it wouldn't work so well with VTACK or Geos (Suzukis).
Old 02-21-2012, 10:01 PM   #25 (permalink)
As to where, the typical source for the Indian small-scale inner-tube bags is digester gas, fed directly to a venturi/carburetor.
It's pretty easy to make digester gas at home. All you need is an airtight drum filled with waste, some cow manure and water (absolutely no air) and a hose to attach that to your balloon or storage container. If you use a rigid storage container and want some pressure, you'll need a compressor attached to that, but if the gas production is large enough, you can also use that to power the compressor.
Old 02-22-2012, 03:42 AM   #26 (permalink)
Originally Posted by redneck
My thoughts on this would be to put the bag in a small lightweight trailer with a hard shell that could be shaped for aerodynamics.
Originally Posted by euromodder View Post
At near-atmospheric pressure, the trailer would hold so little gas that it'd be pointless to tow the trailer around..
Note, I said bag (balloon or bladder). If the commute is short, there should be more than enough gas between fills. (refilling daily if need be)
The main points for using a trailer.
1. to allow a larger bladder than could be placed inside a vehicle.
2. to separate the occupants from the fuel source in the event of a accident.
Using compressed gas in a approved container however, would be the best thing to do.
Old 02-22-2012, 11:07 AM   #27 (permalink)
Elle - '10 Honda Element SC
wouldnt you then require a hazmat cert just to drive your vehicle then and a sign stating what it is carrying?
Old 02-23-2012, 03:21 PM   #28 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Same difference - a balloon is at what 1.5 x atmospheric pressure maybe ?
It's not going to hold a lot of fuel.
Why introduce range anxiety to gas cars ?
Driven beyond their gas range, they'll need petrol.
The main point against it is weight.
It's going to weigh an awful lot of pounds for a ridiculous equivalent amount of gas.
That weight is going to cost some gas as well.
Hence ... why ???
Old 02-23-2012, 06:21 PM   #29 (permalink)
That's a new one on me. lol
I wonder if they make a pill for that...???
Old 03-02-2012, 11:42 AM   #30 (permalink)
Adsorbed Natural Gas Technology Applications
Another approach for biogas storage. Absorbed natural gas storage.
The Following User Says Thank You to Staska For This Useful Post:
redneck (03-05-2012)
