Old 02-21-2012, 08:45 PM   #151 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
Since we're talking about cargo ships now, this seems kind of neat :
Could we Clean Up Air Pollution from Cargo Ships with... H2O?! : TreeHugger
Though it sounds bizarre, mixing water into the fuel helps it to burn better. The heat of combustion breaks water molecules up. The resulting hydrogen atoms help to split hydrocarbon molecules, making them more combustible, while the oxygen released goes on to combine with the carbon, ensuring that more of it burns. [...]
His answer is to use a surfactant. [...] a mixture of oleic acid (a fatty acid found in various vegetable oils) and nitrogen-containing compounds called amines. This mixture dissolves readily in diesel fuel and binds water to it without any need for stirring. The water droplets themselves can be as small as a nanometre (a billionth of a metre) across. That they are so small helps stabilise the emulsion. The result is, in effect, a liquid sponge, and means the mixture can be stored indefinitely, like ordinary diesel, without risk of separation.
The result, when it is burned, is the near-complete abolition of soot, and a reduction of up to 80% in nitrogen-oxide emissions. The surfactant itself also burns without creating emissions beyond water, carbon dioxide and nitrogen.
CarloSW2
American Solar Energy Society
