02-21-2012, 08:45 PM
#151 (permalink)
Pokémoderator
Hello -
Since we're talking about cargo ships now, this seems kind of neat :
Could we Clean Up Air Pollution from Cargo Ships with... H2O?! : TreeHugger
Though it sounds bizarre, mixing water into the fuel helps it to burn better. The heat of combustion breaks water molecules up. The resulting hydrogen atoms help to split hydrocarbon molecules, making them more combustible, while the oxygen released goes on to combine with the carbon, ensuring that more of it burns. [...]
His answer is to use a surfactant. [...] a mixture of oleic acid (a fatty acid found in various vegetable oils) and nitrogen-containing compounds called amines. This mixture dissolves readily in diesel fuel and binds water to it without any need for stirring. The water droplets themselves can be as small as a nanometre (a billionth of a metre) across. That they are so small helps stabilise the emulsion. The result is, in effect, a liquid sponge, and means the mixture can be stored indefinitely, like ordinary diesel, without risk of separation.
The result, when it is burned, is the near-complete abolition of soot, and a reduction of up to 80% in nitrogen-oxide emissions. The surfactant itself also burns without creating emissions beyond water, carbon dioxide and nitrogen.
CarloSW2
02-21-2012, 08:54 PM
#152 (permalink)
Pishtaco
I wonder why the article targets Maersk - a company that's doing more than it officially needs to, to reduce the impact of its operations
Simple. The article was about the largest cargo ships, and Maersk owns the eight largest. Note, however, that supertankers are nearly triple the dead weight tonnage of the largest cargo ships.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
02-23-2012, 02:24 PM
#153 (permalink)
Combustion heat does not split water.
It turns it into steam.
The steam then dampens peak combustion temperatures - I use this feature daily at work - which will help in reducing NOx.
Introducing more Nitrogen (in the amines), and claiming that it'll convert to N2 instead of adding NOx during combustion is also more than a wee bit weird given that plain N2 will turn into NOx when the temp is right..
02-23-2012, 08:36 PM
#154 (permalink)
Pishtaco
Kind of disappointing. This LCA indicates the infrastructure and production environmental costs of making gasoline are only ~1/3 of the environmental costs of operating the vehicles consuming the gasoline (Figure 2).
The greenhouse gas emissions from infrastructure and production operations do exceed the emissions from operating the vehicles (Figure 3).
Darrell
02-24-2012, 10:09 AM
#155 (permalink)
home of the odd vehicles
What is dissappointing is that the article like all of them I read are incomplete.
It is mainly focused on how much energy and CO2 is being used/generated.
Emissions as they define it is CO2, they are not taking into account individual emissions (like sulphur and nox), benezene or VOC either.
05-11-2012, 10:06 AM
#156 (permalink)
Pishtaco
Time for an update. I quit clean hypermiling at the end of April, after completing a 3664 mile round-trip to Texas with a non-hypermiler. We set the cruise control to 60 mph, but did no more. Sum total of my clean hypermiling was 6600 miles at 43.6 mpg, about a 6 mpg penalty for not shutting the engine off.
I haven't updated my mileage logs, but I'm averaging 50.1 mpg on my current 1300 mile trip to New Mexico, v. 41.1 mpg on the 3664 RT to Tx. 9 mpg for just P&G - I'll take it.
Darrell
The Following User Says Thank You to SentraSE-R For This Useful Post:
05-11-2012, 11:46 AM
#157 (permalink)
Hypermiler
Is that P&G with the engine on or off?
05-11-2012, 01:25 PM
#158 (permalink)
P&G is an engine on function
05-11-2012, 02:37 PM
#159 (permalink)
Pishtaco
Engine on, except on the long downhills, Andrew.
Darrell
05-27-2012, 08:47 PM
#160 (permalink)
Pishtaco
I'm back! 50.2 mpg for the last 2400 miles.
Code:
Date miles gal mpg notes
4/29/2012 212.7 5.199 40.91171379 home to reno reno
4/29/2012 328.1 5.823 56.34552636 reno to ely ely
4/30/2012 428.8 8.448 50.75757576 Ely to moab Moab
5/1/2012 335.3 6.576 50.98844282 Moab to Chaco to Farmington Farmington
5/16/2012 499.9 9.996 50.010004 Chaco local Albuquerque
5/23/2012 388.8 8.184 47.50733138 Chaco local Cuba
5/25/2012 242.8 4.321 56.1906966 To ABQ& back Cuba
Totals 0
2436.4 48.547 50.18641729
Darrell
