Thermostats get weak over time. I would swap yours if you don't hold 195 when warmed up. These diesels do better for mpg when up to full temperature. There is a guy on TDIClub experimenting with a 205 degree thermostat and he feels he has gained several mpg from that alone.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
