Old 02-24-2012, 12:14 AM   #18 (permalink)
niky
Originally Posted by euromodder View Post
You can't run WVO or B100 in new diesels that come with DPF .
The current breed of DPFs is actually blocking the renewable fuels option on diesels.
This:
Originally Posted by UFO View Post
Not that I advocate burning vegetable oil at all in modern diesels (I don't), but it's not the DPF that is the problem, it's the wasteful way in which they burn out the DPF to keep it clear. There would be no issue with biofuels at all if the diesel manufacturer installed a low pressure fuel injector into the DPF itself to burn it off instead of injecting fuel into the cylinders, post ignition, allowing liquid fuel into the engine oil.
It's a point of discussion on biodiesel boards, the different consistency of the biodiesel causing the extra squirt to stick to the cylinders and wash into the oil instead of going into the DPF as regular diesel do. And there's no quick fix to this.
Originally Posted by Duffman View Post
Most manufacturers have now stepped up to B20. Also many are starting to use an external injector due to oil dilution issues, it just wasn't apparent as a problem in 2008.
Hopefully they all follow suit.
