Old 02-25-2012, 10:39 AM   #2 (permalink)
drmiller100
VSS in the trans are famous for going bad. also, look for the connector which hooks to the VSS - they get corroded as well.
as for the CEL, you probably don't have the O2 sensor wired correctly. triple check.
