Old 02-25-2012, 11:48 AM   #4 (permalink)
briogio
Originally Posted by drmiller100 View Post
VSS in the trans are famous for going bad. also, look for the connector which hooks to the VSS - they get corroded as well.
as for the CEL, you probably don't have the O2 sensor wired correctly. triple check.
I did take the connector apart and clean it, it did look dirty, and put it back together with electric grease, it seemed to work better at first then it went back to it's old ways. Probably will change it now.
i'll check O2 sensor the wiring again.
Originally Posted by brucepick View Post
Do you have VTEC-E computer for engine management? I suspect different versions of that logic for CA vs. 49 state and standard vs. auto trans vs. CVT.
I do have the PO7-01, which is the right computer, but I need to recheck the wiring.
Also the EGR solenoid is not the original 92-95 VX one.
Thanks for the advice
