Old 02-27-2012, 11:43 AM   #114 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
eq1 - congrats on your success!
Originally Posted by eq1 View Post
One thing that seemed odd, or novel, was, on some of these longer assists, the SoC gauge might drop to 17 or 16, but it would pop back up to 18 or 19 - without having observed the charge gauge charging at all in the intervening time.
If I'm not mistaken, you're just describing "background charging": The car will top up the pack at a relatively low amperage while cruising, without lighting any bars on the charging side of the display.
If you're sensitive enough to your normal "fully charged" (or "pack disconnected via the big-a$$ OFF switch") lean burn window, you'll notice it's harder to enter or hold lean burn near your usual load limit when background charging is happening. Once the pack is back up to ~19/20 bars and background charging ceases, lean burn is easier to achieve/hold.
Final note: my pack has 168,000 miles on it. I'm totally impressed with what I've seemingly achieved with this cycling process... I've probably at least doubled the capacity, maybe closer to tripled
That's great!
So, I guess only time will tell if my pack's revitalized performance will actually last...
I hope you'll keep us posted. I haven't driven my car for several weeks - since I reported my results earlier in this thread. (I realize my infrequent car usage is not ideal for battery health.)
Now I'm waiting on a few parts before I install my grid charger/balancer.
