Old 02-28-2012, 07:20 PM   #1 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
what would you do?
I am taking one more trip to Dallas from Sacramento in May.(1775 miles over 2 1/2 days)
On my last trip I was able to get 32mpg with an 22 epa.
As you may know from previous posts I have done the following:
adjusted nut behind the wheel
scangauge
upsize tires (from 245/45/18 to 245/50/18 27.7" diameter)
43psi
nitro
IMPUL body kit (2" lower)
Lowered front end 1.25"
rear window spoiler
rear trunk spoiler
underbelly in front
underbelly in rear
Grill block behind grill
window tint (rear and rear sides)
window visors
Rear wheel skirts
So I have two thoughts:
1. I have been following the kammback threads and am concidering a clear kammback......
or....
could I acheive similar results by raising or lengthing the rear spoiler?
I was inspired by that windtunnel video with the new mb twoseater where the rear spoiler raised up....
however, I dont want ducttape it to the car. I want to try to make to look proffessional. I have some ideas but dont want to get started unless the group feels that it would help.
Also I have never figured out how to lay the 'templet' over the car to even begin to take measurements
2. I am going to run a lip or dam on the front. Havent worked uot the details because the car scrapes in the front sometimes so I dont want to do something now and drstroy it before the trip. there is about 5" from the ground to the bottom of the lip.
So do you think that doing a lip or dam is worth it for the trip?
Here is a side view of the car:
here is the software that VIIO did:
Here's a model of the air velocity affecting your car at 55mph - red is slow (drag/turbulence) and green/blue is full speed air (low drag = good).
you can see the lip that I had on for the last trip and the skirt in back
here is the front(less the required lic plate)
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
