Old 02-28-2012, 10:46 PM   #9 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I took the overlayed pic and figured that it is 5inches from the top of the spoiler to the bottom of the kammback.
I have a small lip spoiler on the top of the window. I can use that as the anchor point for the top.
I'm thinking of using some polycarb and using a heat gun to curve the corners. Then fit the edges of the polycarb with some foam so that the kammback seals to the body.
I would probably build an aluminuum L bar frame that would have holes in it to hook small bungee straps to.
That way I could use the trunk and easily set the kammback on and off
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
