Old 02-29-2012, 10:26 AM   #31 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Oil Pan, you are clearly no slouch with a wrench.
Why don't you go for some real MPG? Flush that frail 700R4 and transplant in a NV4500 stick shift. Two solid MPG easy, and it opens wide vistas of hypermiling. These transmissions were used with a wide range of GM engines and should be almost a bolt-up.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
