Old 02-29-2012, 01:13 PM   #32 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Big Dave View Post
Oil Pan, you are clearly no slouch with a wrench.
Why don't you go for some real MPG? Flush that frail 700R4 and transplant in a NV4500 stick shift. Two solid MPG easy, and it opens wide vistas of hypermiling. These transmissions were used with a wide range of GM engines and should be almost a bolt-up.
Or just put in an NV3500, your 120-180 HP engine won't upset the 3500 and it can cost as little as $200 for the drop in MT replacement for the 700r4.
AKA an NV3500 and 700r4 have the same mounts, dimensions, etc.
The Following User Says Thank You to rmay635703 For This Useful Post:
meanjoe75fan (05-28-2012)
