Old 03-01-2012, 05:28 AM   #138 (permalink)
eq1
eq1's Avatar
Hmm, I was just trying to figure out if I can charge more than one stick at a time with the CellPro 8. Doesn't sound like it - it sounds like these 'parallel adapters' are just for specific types or brands of battery packs...
"Parallel Adapters: FMA has designed Safe Parallel Adapters to be used with the Cellpro PowerLab 8. Parallel adapters supports one battery pack at a time and may be daisy-chained with other Safe Parallel Adapters. Designed to support multiple parallel pack, node-plus-discharge (high current) charging applications. Multiple, on-board SMT polyfuses (automatic resetting fuses) protect the adapter and charging circuitry from damage from wrong interconnections, reverse polarity, etc. The part numbers for the standard adapters are listed below along with a list of compatible battery packs."
2000 Insight MT, CAN, ~168k Miles
