Old 03-01-2012, 05:59 PM   #274 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
That's probably an "it depends" answer.
Fuel cut (DFCO) deceleration means you'll go a significantly shorter distance than if you neutral coast while idling, so I doubt it's as effective as neutral coasting (because you need more fuel prior to DFCO to cover the same total distance).
I only DFCO when I *want* to slow down more quickly (ie. engine braking). (I don't drive much in hilly territory where I'd use DFCO as a technique to control downhill speed.)
I've never seen any controlled attempt to compare the two approaches. Besides, I suspect the results would vary greatly from vehicle to vehicle, which just makes it an "it depends" situation. No pat answer.
