Old 03-02-2012, 09:10 AM   #4 (permalink)
slowmover
90 day: 19.36 mpg (US)
Originally Posted by Ed-in-Maine View Post
Hi Decksetter, if you don't already have a ScanGuage II real time data from the ODBII port, get one! The constant feedback is great at changing driving habits. On my last refill I managed 17mpg doing cold start short drives 75% of the time. I don't have good ABA but I'm sure that before I would have gotten 15.
Ed
Along with this: careful records of all gallons and all miles (which you may already be doing). An understanding of CPM calculations (AAA and OOIDA downloads) for business purposes. As the truck is a business tool so knowing it's exact relation to income is crucial. Project future fuel costs at $6/gl for some margin (calendar year 2013, for instance; to adjust other expenses in relation). Fuel may not go that high, but I'd rather have a handle on the way it affects my income to make plans now.
I also like to know average mph as a way of keeping any idle time as low as possible. Higher average = better FE. Using MAPQUEST "best routing" is beneficial (similar to how FEDEX and UPS dispatch their trucks).
Fuel economy is seen, IMO, in relation to annual average mpg. Any increases are simply as a percentage increase of that number. 16-cpm fuel cost to 14-cpm doesn't seem impressive until we see it as a 23% improvement (or however the numbers may work).
And it's not enough to know the fuel cost, per mile, but the true cost per mile as well (depreciation, taxes, maintenance, repairs, etc). The adjusted IRS deduction goes to a savings account for truck expenditures. (Every job pays both the truck and the owner . . separately). I pay the truck before I pay myself, IOW. (A good incentive as it makes the truck my expensive helper and not "my slave").
Further, an analysis via records of distances the truck travels per job. Mostly town miles argues against aero (unless really cheap), but extended highway is the reverse. But, in both cases best LRR tires are beneficial (especially if the tire brand/model is known for very long life) such as LT-rated MICHELIN (see their site).
On the truck I'd start with issues of rolling efficiency. Do all book maintenance and a bit more, then:
- perfect (not just good) wheel alignment
- zero brake drag
- zero steering wander
Tires and brakes should be lasting above 70k. If not, then some driver-adjustments may be needed.
Little things, IMO, like polyurethane anti-roll bar bushings (and adding a rear bar if not so equipped; HELWIG or ADDCO) are good for straight-ahead stability. Best shock absorbers (such as BILSTEIN). Wind and bed loads work against that stability and increase steering corrections per mile (which is bad for FE). The side loads imposed by winds on a truck with bed topper are noticeable, especially when loaded up.
When I buy a vehicle my first step is to get a certified scale reading (CAT Scale) with driver, full fuel and permanent load additions. Good to check against in future as gas engined vehicles tend to be weight sensitive and "trunk junk" tends to accummulate over time.
I've seen the argument that a work trailer (carrying the JOBOX and other tools) that can be left at the site (or disconnected on non-work days) is a good way to keep solo vehicle mpg higher.
And little things like LED exterior lamps, etc, may also add to long-term efficiency. A little more up front $, but less electrical drain and they live longer plus provide better performance. A search around this site may reveal more of this kind of thing.
