A high vacuum would be bad. Having about -5psi or 10''Hg is ideal....
You would have to ensure that the rubber crankshaft seals and such would actually withstand such a high differential pressure, between the vacuum in the crankcase and the outside world.
I doubt that normal lipped rubber crankshaft seals would withstand such high vacuum.
More modern seals have very low lip strength, to allow less rotating friction, and would only handle about 1 inchHg vacuum before the seal starts to fail because of the thinness of the rubber.
Jim.
