Old 03-03-2012, 10:54 PM   #12 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
ok
ok
so here we have another car whose owner has / had the same opinion expressed by your self
he no longer has that opinion
most cars when driven at WOT will show 1 or 2 kw retard on one or two cylinders at close to max calculated load , no car when operating at cruise in good condition at 40% calculated load shows knock retard of this magnitude ...
unless
the
system
has
been
tampered with .
if you have tampered with your system and advanced your base ignition timing
and
your system can not perform as graphed above
your system has a serious problem
Last edited by mwebb; 03-03-2012 at 10:57 PM.. Reason: we test for carbon buildup and or failing injectors
