Explain this:
Compare Side-by-Side
The only thing that changed between these two years was the ECU programing, which can be seen and manipulated by the same software that the tuners use. The primary change was advancing the ignition timing by 10-20 degrees across a wide range of the load/rpm bands.
As you can see, the mileage increased... apparently the knock did too?
