Hi!... Very nice job!... Congratulations!
I have just one doubt... looking at the pictures I can't figure out all the fixations from the motor+gearbox to the chassis... I only see the two lateral arms... Is this all that you're planning? If so, it would be interesting if you check the strength of that structure... don't forget that the torque generated by the motor should be contrarrested by that fixation, and the fixation doesn't look strong enough for the torque of that engine...
If you need some help with the strength check, let me know... I work as stress analyst...
Greetings from Austria!
DIEGO
VW SHARAN 7N 2011 2.0TDI 140PS - 50,2 MPG
ex SEAT León 1.4 TSI 125 CV (93 KW) - 36,12 MPG - gasoline
ex VW Polo 1.9 TDI 100 CV (74 kW) - 47,1 MPG - diesel
