Well I'm trying to check if there is any ground or short in somewhere but until now I can't find it.. the most important is that I now its not a serous problem with the injectors because from the ground ( from injectors )to to the Body its not shorten I put in buzz on my MM and there was not shorten ( otherwise will flood the engine )so the problem is in some where that I can not find it...I hope somebody can help me with this..
Paul..
