Old 03-05-2012, 12:15 PM   #11 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by skyking View Post
The glad wrap easily wrinkles and does not transmit a flat surface onto your job. It does work as mold release and I use it to put under parts I don't want stuck to the table.
I have had great luck with it.
I lay up the glass, impregnate with resin, stretch the wrap over the epoxy, and tape it down beyond the wetted area to keep it tight.
And it's stretchable, so it conforms to 3D surfaces.
Works good.
If it wrinkles, then something is shifting and causing the wrinkle.
Jim.
The Following User Says Thank You to 3-Wheeler For This Useful Post:
BamZipPow (11-11-2016)
