Old 03-05-2012, 12:59 PM   #4 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Raising the compression or increasing the stroke should both provide benefits, but remember that milling the head or using a thinner gasket will both throw off mechanical timing.
I wonder if you'd have issues with detonation during lean burn if you raised the compression a little? It only happens under low load operation, right?
