Old 03-06-2012, 03:14 PM   #11 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
I have always used the octane recommended in my car's manual (87) even if the engine has a rather high Compression Ratio (10.5:1). Modern ECU/ECM can easily manage lower octane with higher compression engines by adjusting the timing accordingly, to a certain extent. I might try 89 (E5) or 91 (E0) octane gas this summer and see if the ECM can advance the timing on its own for increased efficiency.
