Originally Posted by jdchmiel
do aftermarket cam / cam gear(s) exist?
Not for fuel economy but if enough of us start using the Ninja for hypermiling we might be able to get something custom ground. If the gears are slip fit, it might be possible to detune the stock cam timing somewhat. I'm not crazy about carbs any more either but it is hard to argue with the thousands of good used Ninjas out there.
