Originally Posted by slowmover
Radii on those vertical edges right behind the cab would be good too, to the extent they stick out from the cab sides.
Which could be added later. Maybe as separate pieces for when taking camper on/off, but clean it up (smooth transitions) when installed.
Folding, removable boat-tail makes real sense.
Thanks slowmover, Maybe I will do something like this out of foam and hinge it to the camper so I can open the rear door.
