Originally Posted by Frank Lee
Re: behind the cab radii: I was thinking you'd cut those in, same as you'd do above, rather than add something on that comes ahead of the back of the cab.
Good point. What you suggest makes the most sense rather than dealing with hinges and fairings but i am going to put the jacks in a hollow tube "receiver" in that area so I can remove them easily for travel. The green square in the pic.
