Old 03-10-2012, 06:44 PM   #25 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by IsaacCarlson View Post
He thinks he can get it down to 2.87ish, which would be perfect.
He also told me that I can use a 5 pin bosch NC relay to drive the B solenoid.
YAY!!!
Sounds good, with that big of a motor the higher you get geared (numerically lower) the better, assuming you do not loose lockup, so anything in the 2.5-2.8 range is probably going to work out well.
Good Luck
Ryan
