Old 03-08-2012, 06:55 PM   #21 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
The axle parts won't swap. They have two different carriers.
I will have to use the 4t40 and alter the B solenoid wiring so it does the opposite of what the PCM tells it to.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 03-08-2012, 10:01 PM   #22 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
If you have the skills and the patience, get it working right (it looks like you did)
and you can always go back in there later and drop in a final gear swap.
Although trust me, once its done and working its hard to go back in.
The fuel savings from going from a stump puller to an airplane can be rather large.
The FE difference on my buick at basically every speed comparing 3 to 4 was massive, at higher speeds I lost about 40%
Spinning that big brick comes at a price, hopefully you mainly want this car as a town hopper and it won't be too bad for that.
If you do venture on the highway get a fuel economy guage of some sort, I would guess 40-50mph will be your sweet spot.
This may be one of those oddball situations where big tires would save fuel, if you want to scrap out the wheelwells and find some light 19" or 20" wheels
Sadly 20" wheels cost more than the final though
Good Luck and keep us posted.
Old 03-09-2012, 12:32 AM   #23 (permalink)
Team Pontiac
I am not really sure what I can do with the final drive right now. It seems that is the lowest I can go. I will call a tranny shop and find out for sure. It sure would be fast. I could always sell it for $$$$ and get a fuel sipper.
1991 F-250:
Old 03-10-2012, 12:10 PM   #24 (permalink)
Team Pontiac
I have a guy looking into the final drive on the 4t40. He thinks he can get it down to 2.87ish, which would be perfect. I will be installing a few new components in the tranny to make it hold up to the power.
He also told me that I can use a 5 pin bosch NC relay to drive the B solenoid.
YAY!!!
1991 F-250:
Old 03-10-2012, 06:44 PM   #25 (permalink)
rmay635703's Avatar
YAY!!!
Sounds good, with that big of a motor the higher you get geared (numerically lower) the better, assuming you do not loose lockup, so anything in the 2.5-2.8 range is probably going to work out well.
Good Luck
Ryan
Old 03-27-2013, 11:54 PM   #26 (permalink)
Team Pontiac
3800 sunfire update
I have done a lot of figuring over the winter and started working on the car again today. Not much, just getting my bearings again....LOL
I am looking for any ideas on the gearing. I have to get a new chain and sprockets to handle the extra power, so the mileage won't be too bad to start with.
Current gearing: 3.91
New chain/sprockets: 3.05 should be a huge improvement
New diff: 2.54 $1000+
Would it even be worth it to mess with the diff?
1991 F-250:
Old 03-28-2013, 08:38 AM   #27 (permalink)
at a thousand bucks? No.
Old 03-28-2013, 10:26 AM   #28 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Why such a big engine in a sunfire? Isn't that a cavalier?
Old 03-28-2013, 10:42 AM   #29 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Chain and sprockets?
For a moment I thought maybe it was a motorcycle, or a project car with a motorcycle drivetrain.
Your car's page:
Details: 3800 Sunfire - 2002 Pontiac Sunfire Fuel Economy - EcoModder.com
Anyway, I don't see how swapping in a 3800 cc engine to replace a 2200 cc engine will improve fuel economy. Unless its actually a performance project and you just want to make some effort to keep it from becoming a total fuel hog. In which case you may be on to something.
But what are the chain and sprockets?? I don't think you'd be changing the gear ratios of a timing chain. It must be something else.
Coast long and prosper.
Old 03-28-2013, 11:20 AM   #30 (permalink)
90 day: 57.73 mpg (US)
Isn't there a thread about your project already?
It makes more sense to post your updates there than to start a new thread. Post the link and I'll move these posts over, if you like.
