Old 03-10-2012, 07:28 PM   #86 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Are you using a deep cycle battery, or starting battery?
Also, when its colder, a battery's voltage will sag more under load. As it gets warmer out you should see it recover at least some.
It is deep cycle, but I opted for the unusual step of a much smaller battery, an Odyssey PC625, which was actually designed for a motorcycle. I greatly reduced electrical loads (lights mostly). I have wondered if the 40amp current from the alt might be overcharging and damaging the battery: how powerful is the typical motorcycle alternator?
