Old 03-11-2012, 11:33 AM   #26 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Mr. Previa View Post
Green Energies LLC, 15 amp., 12/24volt.
This one? Solar Charge Controller 12 Volts 15 Amps [SCC1215] - $12.95 : Green Energies E-store, Solar Products. That's a nice little inexpensive unit.
Originally Posted by toc View Post
What kind of MPG improvement can be associated with the alternator kill switch (considering you still need to charge the battery)..?
Depends on your vehicle. MetroMPG saw something like 10% by unbelting the alternator on his Metro. I have seen less of a benefit, 3-5%, because my Civic has a "smart alternator" that modulates load according to needs anyway, so there is less to gain.
The voltage regulator should be stopping charging and thus no alternator load once the battery is charged, or have I got that wrong?
Yes, you have that right, if your car's system is "smart" in the way I described above. My understanding of older charging systems is that they run alternators constantly.
