Old 03-12-2012, 02:07 PM   #4 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by WD40 View Post
IMHO it would be more effective to disable the appropriate injector and leave the valves alone, it seems to me that by shutting both intake and exhaust valves the piston would essentially be creating a vacuum causing even more issues.
Leaving the valves closed basically uses the air as a spring. The piston uses energy to compress it, but the air pushes the piston back down on the other side of the stroke. Leaving the valves open would waste the compression energy.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
Frank Lee (03-12-2012), jime57 (04-09-2012), mikeyjd (05-14-2014)
