Originally Posted by rmay635703
If you manage to delete EGR safely let me know, my folks need to clean the intake and turbo nearly every year because of EGR, I found a guy with a Vag com but our car was inop at that time so we couldn't change anything.
Ah well, see if I can find him again.
I have done it. Here is a picture of the device I made, you wire this to your MAF harness. To disable the valve, you just need to plug the line with a ball bearing and re-insert the hose on the valve. It's quite stealthy; the CEL stays off and the EGR appears connected and appears to work, even if you look at it with VAG-COM.
