Old 03-14-2012, 04:51 PM   #9 (permalink)
JediSpam
JediSpam's Avatar
The TSX - '08 Acura TSX
90 day: 33.06 mpg (US)
Originally Posted by jamesqf View Post
Depends on whether you know if it's likely to have been serviced according to Honda's service dates. The recommended replacement interval is 105K miles IIRC, so unless you've a good idea that they've been replaced already, it'd be a good idea. As mentioned, they are indexed, and come in A, B, C, and D sizes. The proper size should be stamped on the cylinder head next to the plug hole.
It's also time to check & adjust valve clearance.
Another item to check/replace is the cabin air filter. You have to remove the glove box to get at it, but it's not hard.
same thing as performing a valve adjustment?
