Old 03-14-2012, 07:03 PM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mikehallbackhoe View Post
I have a 84 crx with the 1.3 and high gear ratio. they came stock with 165 70 13 tires. I just bought this car, and it has 175 70 13 tires on it. I am having a hard time finding stock tires, will the 175 tires hurt my mpg much?
That depends. They must be a little heavier, a couple pounds each, probably, doubled as "rotational mass" you have 8-16 lbs more for the whole car. That's not a lot of weight. In the city it'll affect mpg marginally--maybe insignificantly--but on the freeway it's virtually nothing. And on the freeway slightly larger tires such as these will reduce you cruising RPM, probably benefiting MPG. It's as if you gave yourself taller gearing. I hope that helps.
