Old 03-15-2012, 11:30 AM   #93 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Yes they will. Lead acid (flooded, gel and AGM) will do this but a lot of times they are so massive the battery can handle hard fast charging for a few minutes to replenish the drain from start up.
They cant take that for extended amounts of time repeatedly.
Need to slow it down a little.
LiFePO4 packs are even worse about soaking up all the alt power they can get, due to low internal resistance compaired to lead acid.
Uncontrolled charging is not recomended. Slower is better (less really is more in this case).
So this is really important, as I move toward trying to create a plug-in and solar external power combination to keep my alternator off nearly all the time. I need to replace the battery I seem to have ruined with deep discharges (live and learn). I'll go larger this time, and might directly imitate brucepick's design described in this thread. Can I get a single power controller that would regulate charging of the larger deepcycle second battery from all of three inputs, solar panels, the alternator, and plug in? I imagine yes, but I am unfamiliar with the hardware.
