Did minor of works on this F350.
Did replace all ROT vac rubber lines so it build boost early than it used to. They were badly ROT you couldn't see outside until you look closely.
After inspect front end it pop to me that 3 belle tires shop who did alignment told me that everything is 100% perfect. They ever told me that driver side won't affect tire wear. WRONG I was measure tread and it was definably wear faster on inner tread. I put level on it. It confirmed it was 1" off. Must image it cost me alot fuel for that. Hoping new camber bushing fix that.
This why I do works myself. It easier to have them do alignment cause I had bad back/knee to get up/down millions times to look at tape measure on tires to get equal.
It confirmed that I had 3 bad injectors that suck all fuel to waste. Still waiting for guy to get title on truck I want pulled 8 injectors they only had 15K miles. No engine code for bad injectors. There miss on cold engine.
I am try find good price on Tonneau cover. I can't afford $300 cover.
