kennedy adapters will have an adapter kit for pretty much anything you can imagine. they have a good website.
you should have a 4l60e transmission in your suburban. it is computer controlled. the 700r4 is the same transmission, older, which was not computer controlled. there are lots of 700r4's out there.
All that being said, there is a BIG difference in price between diesel fuel and gas. I don't know you will really save that much money.
what kind of mileage are you getting now? You should be seeing 18 or so on the road.
old chevy TBI's are FAMOUS for the ignition timing becoming retarded over time due to timing chain stretch. double check your ignition timing.
