Old 03-16-2012, 02:04 PM   #9 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
An engine swap under your belt makes you a bona fide hot-rodder.
A 6.2 or 6.5 will be an easier swap than a 4BT3.9, but the latter may be more satisfactory in the long run.
Having 300,000 miles with a 6.2 I recommend that if you have the sand for an engine swap, go whole hog and do a transmission swap. diesels are so right with manuals and so wrong with automatics. My 6.2 destroyed seven automatics including two TH400s. Not just "it won't shift" but spectacular failures scattering burnt ATF and blue-colored parts down the road. GM offered a NV4500 in thiose trucks about that time so a five-speed should bolt right up to a 6.2 or 6.5.
There is a whole website devoted to 4BT3.9 swaps.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
