Old 03-16-2012, 10:17 PM   #14 (permalink)
JasonG
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
My truck loves the bio, smoothes right out.
Originally Posted by Big Dave View Post
I wouldn't run No. 1 much with an old-style Bosch or Roosa-Master injection pump, but I don't think it will hurt HEUI (pumpa dusa) or common-rail injectors. these are not as dependent on the fuel for lubrication.
I've got to dissagree Dave.
The pumps his 86 have will push nearly anything fluid enough to get through the single hole hole injectors.
The VE engines (1999-2003) are very flexible as well, but the 4 hole injectors don't like crankcase squeezings and SVO too much.
The pump duse needs very clean fuel due to the close tolerances in the injectors but can run #1 or #2 or b80 with no issue. As you stated, lubricity comes from the engine oil.
The common-rails............. lack of lubricity, even a single gasoline "oops" can cause a catastrophic high pressure fuel pump failure. Look up HPFPF especially on tdiclub.com.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
