Yeh a small power stage (say 50A) is used to control the field power. With Paul's 6 output board this would be very easy. Hint ,Hint , wink , wink
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
