Old 03-21-2012, 11:12 AM   #11 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That is why I use 22+ volts (panel in sun with no load) to charge a 12 volt battery.
Normally 17 to 18 volts (panel in sun with no load) are used.
Okay thanks guys. Now I am learning something (I hope). I get the point about the angle of the sun and output. Maybe that's best. I want to change the house over to solar anyway. But this mod was for portability of a power source that was not the alternator. It is true that a mere trickle charge will likely damage my new battery. I don't want to go much under 6 amps.
Oil Pan 4: I don't understand how a 22+ volt open circuit panel would solve the problem of amperage, though maybe that's not the problem you're proposing to solve. When I run 24 volts and 100 watts through an Ohms law calculator I get amps at 4.166666666666667, which is still quite a lot under the 6 minimum I probably should guarantee (for the life of the new battery).
This seems like it would be a misguided project, and that the home panels are the better project.
